Several problems. The depth is greater at the top than the bottom due to the tracking. Tis not much at any location.
The base of the baffle I had built was, as it turns out, greater than what I needed. 3/4 t 3/4. That, combined with the fact it is that the ring is too far to the front makes it to where the door panel does not go back on all the way. There is not too much room to shift the ring backwards though -- you run into the back of the map pocket pretty quick.
Also, the ring has to be pretty narrow or you start to run out of room where the door panel meets (even after you make the changes I mentioned above).
Once you get past all that, I really start to realize how stupid all of this is since the driver is (at least) partially pointed at the fvcking door panel -- so how good can I ever expect this to sound.
Car audio is stupid.
Goob is stupid.
This server will be stupid in a couple more hours.
/thread.
No wait, don't end CT.
