Crunk Times, My friend.....Crunk Times
Dawson, I tried that gas station trick and it said "Please pick up reciept inside" like yours did. I still think it works. I'll try again when the Jimmy needs gas. I also picked up a red "Sounds Unlimited" sticker for you.
Since you reached 10k and all..... It was the least I could do. Litterally.
If you drop a single coin off of the top of a skyscraper it can penetrate concrete - and lots of it.With that in mind I do not see why a high-velocity acorn couldn't break this layers of glass...even safety-layered / tempered automotive glass
Actually, with a penny atleast, it will reach its terminal velocity as it falls which is not fast enough to be fatal or break concrete.
If you propel the acorn with something besides just gravity, I'm sure you can break glass.
Actually, with a penny atleast, it will reach its terminal velocity as it falls which is not fast enough to be fatal or break concrete.If you propel the acorn with something besides just gravity, I'm sure you can break glass.
Did you know that if you drop a bowling ball, a baseball, a marble and a ninth grade science teacher out of a window at the same time they will all hit the ground at the same time?
bdawson72
Finally Has Bass Again
bdawson72
434/804, Virginia 15's:Yezzir
▼)Ñ╩fZΣµ&
