Crazy dual ABC design?
nweibley
this:annoyinginsomanyways
475
Tampa, FL
I was farting around on paper today, playing with ABC boxes and I drew somthing I thought might actually be pretty intresting to build.
Tell me if you guys think this could work in a good way with the proper application of math and trial and error, it is basically just an ABC box on each side of the wave of a speaker.
Interesting. I never seen something like that before. Looks like a different type of bandpass box. Also that box is going to take up some room, I don't know if the output will be worth all that box space.
Hrm.. could be.
My goal is to make a HT enclosure with crazy beautiful flat low end. I dunno, I'm just going to fart around with MDF and PVC for a few months and see what I can come up with //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I was also considering porting the two 2/3 chambers together with a port length that provides out of phase response for most everything about 15Hz, but in this box, I think that would be alot more trial and error.
Ive seen plenty of these cars with ten inch sub/ subs inverted/facing up and ported to the rear.. even a single 12
884
Nothing wrong with the system. humming sound. Just the amplifier. Just switch it to volume maximum, then enjoy the music there. Loud. Sorry...
12
PSI car audio platform 3 15" with upgrades to handle 3k watts. Or 2 PSI platform 2 12"s. EXOcontralto uses PSI subs with Incriminator audio amps...
4
163
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
929
nweibley
nweibley
Tampa, FL
nweibley
Jimi77
    Jul 13, 2024
Jimi77
    Jul 13, 2024
