Crack in foam of my X8
ok, just saw, here for europe the easiest available is E6000. but it says its for jewelry... is that ok?
will it support the constant vibrations of the foam??
I suggest AquaSeal. Urethane based stuff like silicone rubber but much tougher.
John Kuthe...
your offering suggestions on repairing/fixing a speaker yet you can't even install 2 amps on your own??
Completely different animal, plus know quite a bit about adhesives and plastics, chemistry, etc. You are engaging in baseless ad hominem attacks.
John Kuthe...
John Kuthe...
You have a history of being completely ignorant on topics you say you know.
Do you know how silicon affects foam?
You have a history of being completely ignorant on topics you say you know. Do you know how silicon affects foam?
Aha, valid point. The solvents in any adhesive may adversely affect plastic foam. Good point.
I once fed an unusually large number of packing peanuts into a small glass bottle with just a small amount of gasoline in the bottom of it! Afterwards I had a little sticky liquidy mass of solvent melted packing peanuts, probably polystyrene or whatever polymerized plastic they made the packing peanuts from.
Best for the OP to get the whole speaker reconed if they want to get a good long life out of it. Plastics never last well. Some better than others for sure, but they will ALL be reclaimed by Mother Nature and entropy, eventually.
John Kuthe...
recone.... the sub is only a few months old. I don't have any Sundown retailers here in spain.
maybe sundown could give me a hint? I don't want to glue it, screw up the foam and then loose warranty either...
thanks
XxAndreaxX
spain
Boomin_tahoe
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
