couple Qs.
smokeoff
here's my 3 cents
1,114
Cambria,WI
1. Rate 1 15" XXX on 1500 brutus tuned to 28 hz againts 2 12" Ks on Avionixx 800.2 tuned to 30 hz.
2. would a 130 amp alt handle 1500 watts fine.
3. is the new A going to be in the same class as the XXX. would it be worth the wait or will their not be much differnce.
4. sister has to polk GNXs and a profile amp. GNXs are rated at 175rms each. amp is rated 300rms 4 ohm 420 2 ohm. How should I wire.
Thanx
I relocated the head unit ground, and I also put plastic wire loom tubing over the RCA cables since they sit on the bare metal floor under the...
6
12V is well within the range of acceptable voltage for most mobile electronics. How much power you're leaving on the table not feeding your amps...
6
The SIA is a great line of amps. People like to hate. My little SIA does work with 4-8's. And it bangs the lows.
23
7K
smokeoff
here's my 3 cents
smokeoff
Cambria,WI
smokeoff
Bobbytwonames
    Jul 19, 2024
Bobbytwonames
    Jul 19, 2024
