Computer Monitor Question...
joetama
The British Ear
Ok so...
I hate the screen on my laptop. When I'm at home I use a Dell monitor I got and it looks great. (1280x1024 resolution)
So, I went out today to get me a new monitor for when I am at work. I walk into the store, which is a Micro Center so they have a lot of selection. All they have are 'Widescreen' monitors. I asked a sales guy if they had any 'normal' monitors. He told me no and that most stores don't even stock them anymore. So, I asked him if I could use a widescreen monitor? He told me no that most laptops don't have the video processing to run widescreen or look good on an external monitor, which seems strange to me since I run it almost all the time on an external monitor. (Then he proceded to tell me about there new laptops which will run great with a widescreen monitor. I politly told him to go **** himself and left the store. Then after going to several other stores I've found pretty much no one that can answer my question. Nor did I find a single store that stocked a standard ratio monitor. Anyway, I've got a pretty new Toshiba laptop which is widescreen (IIRC) on it's built in monitor. It also has nVidiea (spelling?) 5700 or something built into it, I don't have it with me right now but I will look later.
So, my question is the guy a retard or is he right?
Also, what desktop monitors do you guys use? Where did you get them?
Thanks,
-Joe
i have a 19" 4:3 lcd FS in the misc section;)
is your laptop a 4:3? if so the native resolution is going to be a mulitple of that(i.e. 800x600, 1024x768)
if you drisplay it on a widescreen it will stretch the picture to fit(1024x768 -> 1360x768) which is barely noticeable
you could also try going into the advaced section of your video adapter and forcing it to display the correct resolution
i have onboard video on a P4 machine and it can display a 1900x1200 res on my 24" lcd so video card performance shouldnt matter unless you wanna game
Most LCD manufacturers have moved over almost exclusively to widescreen as the demand for standard 4:3 and 5:4 ratio monitors has fallen dramatically over the last couple of years.
Your laptop's screen is likely a 1280x800 widescreen unit (8:5 ratio), so it should have no problems scaling to a widescreen monitor. However, the screen will probably have a different native resolution than your laptop, so if you want to use both screens at the same time, the monitor may have some scaling artifacts (depends on the quality of the scalar used in the monitor and the type of connection).
If you are just using the monitor, it shouldn't make any difference at all as you can just set the output resolution to the native resolution of the monitor. Note that the graphics unit may not necessarily support all resolutions, but a modern laptop should support all the major ones (i.e. 1440x900, 1680x1050, 1920x1200).
joetama
The British Ear
joetama
Cincinnati, Ohio
joetama
