trumpet 5,000+ posts
Barry Schanz
A Stock, New In Box, Factory Warranties
Links to specific models are included when possible, but the prices shown on our store are not the closeout specials. Due to the low quantities and because these will be drop shipped I have to ask you to pm me. I will check availability and get you a quote today.
Diamond Audio Closeouts - BIG discounts on these amps, ask me:
TX10001 2200 Watt 1 Ohm Stable Mono Block
TX6001 1200 Watt 1 Ohm Stable Mono Block
TX6004 1200 Watt 4 Channel
TX3004 600 Watt 4 Channel
TX3002 600 Watt 2 Channel
Massive Audio
NX3 - 3 Channel 120W x 2 @ 4 ohms, 240W x 2 @ 2 ohms, 600W x 1 @ 2 ohms, 800W x 1 @ 1 ohm
Cerwin Vega Closeouts:
HED3100.1D 1000 Watt Mono Block 2 Ohm Stable 350W @ 4 ohms, 550W @ 2 ohms
HED3100.2 1000 Watt 2 Channel Class AB 100W x 2 @ 4 ohms, 200W x 2 @ 2 ohms, 400W x 1 @ 4 ohms bridged
HED31200.4 1200 Watt 4 Channel 100W x 4 @ 4 ohms, 200W x 4 @ 2 ohms, 400W x 2 @ 4 ohms bridged
HED31500.1D 1500 Watt Mono Block 550W @ 4 ohms, 950W @ 2 ohms
HED3500.1D 500 Watt Mono Block Class AB 170W @ 4 ohms, 350W @ 2 ohms
Stroker STKR1000.1 2000 Watt Mono Block, 1 Ohm Stable Class GH, 1,000W @ 1 ohm, clip indicator LED, temperature controlled cooling fan, Recovering Thermal Management System, differential balanced inputs
Stroker STKR800.4 1600 Watt 4 channel Class AB, 200W x 4 @ 2 ohms, clip indicator LED, temperature controlled cooling fan, Recovering Thermal Management System, differential balanced inputs
VEGA 600.1 1200 Watt Mono Block Class AB, 600W @ 1 ohm, differential balanced inputs
VEGA 250.2 500 Watt 2 Channel Class AB, 125W x 2 @ 2 ohms, differential balanced inputs
VEGA500.4 1000 Watt 4 channel Class AB, 125W x 4 @ 2 ohms, differential balanced inputs
RE Audio Closeouts:
CTX 1000.4 1000 Watt 4 channel 100W x 4 @ 4 ohms, 150W x 4 @ 2 ohms, 300W x 2 @ 4 ohms bridged
CTX 1600.2 1600 Watt 2 Channel 200W x 2 @ 4 ohms, 350W x 2 @ 2 ohms, 700W x 1 @ 4 ohms bridged
CTX 3200.1 3200 Watt Mono Block, 1 Ohm Stable 400W @ 4 ohms, 750W @ 2 ohms, 1200W @ 1 ohm
CTX 4200.1 4200 Watt Mono Block, Class D, 1 Ohm Stable 550W @ 4 ohms, 1,000W @ 2 ohms, 1500W @ 1 ohm
DTX 1600.1 1600 Watt Mono Block, Class D, 1 Ohm
DTX 2000.1 2000 Watt Mono Block, Class D, 1 Ohm Stable
DTX 600.2 600 Watt, 2 Channel
Massive Audio
RE Audio Closeouts:
