Clear Enclosures?
I know you can do it with plexiglass but I think it's expensive and hard to do.(correct me if I'm wrong) One of my friends had one that was an all plexi bandpass box, looked cool.
Main concern would be flex. Also, must be tough to seal together if it's even possible. But some subs look so nice it's a shame to hide them under MDF.
You can do it, but it isn't the easiest, and costly to get thick plexi or lexan or the like... Also, seams can be a pain to have looking nice, requires some polishing and scratches easy...
THIS IS THE SAME AS THIS: One coil + to the other coil - (on each). The other + & - to the terminal block. Terminal blocks wired straight...
i see, good to know At least. that means i could squeeze out more air volume indeed. bit of a crude design but so far was thinking of roughly...
Yeah. Same thing here. The under seat box I did for the 8s was 325$. He’d already wasted that much with 2 prefabs that sounded like ass.
6
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
sungwei
sungwei
lkj
slick rick
spokey9
    Jul 17, 2024
1aespinoza
    Jul 15, 2024
