Checked gain with an O-scope, sub is still smelling
I personally don’t think there’s a huge amount of difference between ofc and cca. I mean if you’re running on the limits of the wiring, then maybe, but if you’re running several runs, I’m not so sure it makes a big difference. It seems like you could make more runs of cca for the price of ofc, in some cases. It’s been a while since I’ve ordered 50 foot roles of 0 gauge though.
my point exactly. ofc is so expensive. and only really necessary in high end builds. even if he decides to upgrade. he can just make another run into a distribution block. respect the rating on the electrical and you will be fine. those ratings are wayyyyyyyy conservative believe me.
I have had problems with it myself and won't even use it in small builds personally. If you're going to DIY you can always take the power cables out when you move on and good quality copper cable will last for decades. Cabling is likely to outlast every other component you're putting in your car so IMO there's no reason to cheap out on that.
What issues have you had? I'd genuinely like to hear to cram info into my mind-database
I had it on my 300 amp alt, oversized it just because it was under the hood, and that cable didn’t flex or sag at all. Stayed right where I wanted it to.
Theoretically the only things you would really need to watch for is heat, and spikes in resistance, which is connected to heat.
If you are stressing cca to its limit you may see problems with voltage drop and cause the amp to get stressed.
You may also be a TINY bit less efficient in normal operation but nothing that really justifies the price imo.
If you just dont want to make 4 runs of cca for a cleaner look and less wiring go for it. Or if you are running a 370 amp alt you will need it Those runs are barely 3 ft long in the engine bay. They can take alot of power.
Only real men run 4/0 on their alts :cool::LOL:
Failure at connection points and even wire breaking inside the insulation. Aluminum just isn't as malleable as copper so if it's subject to moving it will fail after far fewer bends/flexes and I've seen some awful stuff happening where it goes into distro blocks. Could just be anecdotal and other factors that caused the failures but again, your cable should out-last every other piece of equipment you're buying so why cheap out?
If you absolutely must use it, be sure that every part of your run is very secure and won't move around anywhere and keep an eye on terminals, distro blocks, and fuse holders.
Thanks for the info. Never personally seen that, that's why I asked. I'll keep that in mind for sure.
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
374
I hold firm on the deposit in all situations 😎
838
  • Locked
I dont see a Username and date on any of these pics that the FOR SALE Rules Should Apply. Are these pics off Ebay?? Place those with the pics so...
Voltage for the signal? What does that mean? Electricity isn't measured in purpose. Gain is a characteristic of a circuit. You aren't adjusting...
20
5K
g_cirillo
g_cirillo
Arizona
Buck
    Mar 27, 2024
Daniel Lee
    Mar 27, 2024
