Cheater Amps
the cadence were good cheater amps, but think got banned.
the re i think was good, rated @ 35@4ohms i believe
u could go w the tantrum 1200, rated @ 250@4ohms.
Looking for under-rated (IASCA) amps. Spill'em if you know of some. Looking to stay in 0-300 w/ most amount of wattage as possible. (makes sense)
NO Dei products or US Amps
my pg t1200.1 puts out 1491wrms 4ohm at 14.4v
but the amp is iasca/usac rated for 250wrms 4ohm at 12.5v
HCCA is not a DEI product. The HCCA line was canx'd when DEI bought ADST (old parent company of Orion).
Any amp that makes more power into a lower impedance is a "cheater" amp. If it makes more power at 14.4V it would also fit the bill. That is how PG rates their Tantrum series so low for IASCA (12V@4ohm) but then puts the real power numbers in the 14.4V rating. It will make close to the 14.4 numbers @ 12V but it allows them to basically derate the amp and give the correct power numbers at the same time.
InhumanAcura
1/3ofTEAM PwNAGE..*****es
InhumanAcura
South Florida
tat2
RobGMN
    Apr 28, 2025
ThxOne
    Apr 28, 2025
