Car stereo shuts off when I turn up volume
  • 2
Bigbee246
Ever since I got my Sony headunit which has a built in 45w amp I have been having problems with it shutting off when I crank up the volume to around 45-50 (50 is the max volume) and the bass hits. I have replaced my battery, alternator, checked my ground, and it still does it. I did however find out that if I disconnect one of my rear speakers it does not do it. It doesn’t matter if i disconnect the rear left or rear right, but it does seem to solve the problem. I’m thinking that having all 4 connected just draws too much power out of the amp and it shuts off because it doesn’t have enough power. I am going to do the “big three” grounding mod soon to see if that helps any. Also my dome light dims really bad when the bass hits, even after replacing the alternator and battery and I even cleaned up the terminals and ground. Any help would be greatly appreciated!!!
You can go to theyre Website and check it out/do some research on your own, or even give them a call
33
6K
It should be called the accessory wire...it should be connected so that it only see power when the car is on...if its connected to constant power...
778
Unless Android made some big changes to their core program, it should work just fine. Just like using a 4g phone on 5g sevice.
If the original plugs have been cut off, you may want to get some from a wrecked car. You could also search online for a radio pin-out for said model.
Bigbee246
Bigbee246
keep_hope_alive
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
