BY PASSING THE HAND BRAKE
The hand brake just shows grond signal, so you could just hook up a toggle switch, one wire grounded, the other to your input wire,
BUT the parking brake wire actually switches polarity, from 12v+ to ground, your unit may actually be required to see this "switch", but the alpine, pioneer, and clarion flipout just need to see the ground input,
If your unit has a handbrake and a foot brake inputs, the footbrake input will need to see a 12v+ input, so you can hook this wire to the actual footbrake wire and then install the toggle on your hand brake wire, and while you riddin' down the road, just tap the foot brake while you flip the toggle to give the pan. unit the apporpriate inputs.
did i miss somthing?
and
's dont work here. just hit RETURN //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
um. stop typing in capslock too.
Well I'm pretty negative, I had a bad childhood, and I hate people...
I just didn't see the point, does that make me pissy???
just try being a smart azz sometime. Its kind of fun. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
ntwan
ntwan
new orleans
tRiGgEr
ThxOne
    Aug 15, 2026
TechGuru88
    Aug 10, 2026
