bump in trunk
I have a Pioneer 6 disc changer mounted in my rear deck which is right above my dual 12" subs and I haven't had any skipping yet. But then again I don't crank it up to its limits that much at all. It could be your subs causing it. Is that the only time it skips.??
Adam
It is very possible and likely the cause. Although most Eclipse cd players are real good about skipping. Try using Dynamat, fatmat etc. This should take alot of the vibration out of the trunk panels.
It really shouldn't be skipping. Those things are made to be relatively skip proof but as was stated above, try some dynomat or move the CD changer somewhere else.
I have had the eclipse changer for almost 3 years and it has only "skiped" a few times. The time it was when I was listing to a song with alot of bass. I was mostley wondering if have the changer in the trunk with the subs was a problem. I also wonder if the tempature changes effect the performace. the truck of the car is frezzzing cold in the winter and boil'in hot in the summer. Over all the eclipse changer has performed flawlessly. It also could be the physical condition of the cd. Anyway thanks for you input.
That's not a bad idea. I can get glass resin cheaper than cld sheets too. I could put cld over the glass to add more weight without having to just...
20
495
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
7
917
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
4
Cathlock
Cathlock
Utah
Cathlock
spokey9
    Jul 17, 2024
1aespinoza
    Jul 15, 2024
