Build A Sub Sonic Filter
boister77
SoCal
has anyone built a sub-sonic filter for an ampilifier? my current amplifer does not have a ssf which i now need. i finish building my ported box for my brahma and i want to use a ssf to protect the sub from sub sonic audio. i was planning on bying a new amp with a ssf built-in but i feel my current amp should be sufficient for the time being. anyways i would like to place the home made ssf between my crossover output and amp input, making it a line level ssf. in reality, i would be building a 28Hz "high pass" filter. i've seen a few on these "high pass" filters on partsexpress but i find that $50 is quite a lot. also, they only have a 20hz and 20hz pass.
what is your box tuned too??? If it is low enough you shouldn't need a ssf
Jon
my box is tunned rather low, 28Hz. i know that box tunned low usually does not need a ssf since most songs don't go below 28Hz. however, i like playing "bass" and test tracks and some tracks hit below 28Hz.
after browsing the web i ran into company, harrison labs, a product which i want to build.
sub bass blocker
however, it's a ssf @37Hz. anways, i posted the link so people can have an idea of want i want to build.
Alright man .that is what i have been leaning torwards .i appreciatte your opinion . I feel like the 18s will be great for a daily without having...
7
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
https://www.youtube.com/@therealmatty_s/videos
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
boister77
boister77
SoCal
boister77
spokey9
    Jul 17, 2024
1aespinoza
    Jul 15, 2024
