Bridging Questions!
Jonahdude
I'm thinking about getting a Pioneer TS-W305C Subwoofer and powering it with a Pioneer GM-5000T Amplifier. It's a two-channel amp, but it says it can be bridged to 380x1 RMS @ 4 Ohms. My question is, if I bridged it would it be the same as if I had a 380w mono amp? Also, how exactly do you bridge an amp?
the only difference from a mono amp is that you wont be able to run it at 2 or 1 ohm in bridged mode.
the way you bridge them is different. some have a switch, some dont. some you use the positive from one channel and the negative from the other. read the manual to check how to do it on that amp.
JB
Jonahdude
Jonahdude
Florissant, MO
Jonahdude
Emanuel Rodriguez
    Apr 19, 2025
Emanuel Rodriguez
    Apr 19, 2025
