Lucky
Ok, i was wondering what is the relationship between the size of a sealed and ported box to SQ and SPL
So where would you rate 26hz? That s what the maker of my subs recommends?Some people like to tune their box in the mid to low 30's and some like them higher. (it is a personal taste).
No, it just means that that is the lowest frequency you should run through the sub , because once you go below the tuning point, excursion goes up very quickly. The frequency that you tune to depends on your needs, and if that includes SQ, then cabin gain should be incorporated into the response function so that you don't get any peaks.This may be a stupid question but.....Does the tuned frequency of a box mean that the frequency its tuned to is the optimal frequency(you should play) toget the most spl out of it? If ya know what I mean. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
