Luminare
I think I have this figured out but I am not sure I have been working with WinISD a bit to figure it out, The Sub I am using is an
AudioBahn Alum12Q
FS:22.4Hz
Qts:0.47
Qes:0.52
Qms:4.8
Vas:76L
Vas:2.66ft^3
Re:5.4ohm
Le:2.7mH
Mmd:186Grams
Xmax:+/-14mm
RMS:1000W
Sd:0.049M2
EBP:47
Freq Resp:18Hz-500Hz
Efficiency:96.4db
Depth:5 5/8''
Hole:11 1/8''
Diam:12 3/4''
Displacement:0.18ft^3
The AudioBahn Box Specs suggest:
Air Space: 1.75ft^3
Port Size
1)4x12.3
Port Vel:14.71%
-3dB: 30.1Hz
Tune Freq: 35Hz
Sub Disp:0.18
Port Disp: 0.092
Total Vol:2.0ft^3
Im driving a Civic HatchBack with a large trunk space so I made the box a tad bigger at 4.0ft^3 Is this an ok thing to do? I measured out a box thats 35.15'' x 13.25'' x 19'' with a port thats 8.95'' x 3'' x 10.10'' Deep and tuned to 35Hz On WinISD it shows a peak curve at about 39Hz 6.7dB... Is this alright, Im more techno hiphop style music, Quality doesnt have to be great I know its an AudioBahn ... but I was wondering if someone could check the numbers and all..?
Also what do you guys do to brace the box well?
Thanks. //content.invisioncic.com/y282845/emoticons/toast.gif.bc0657bf54b9ee653b6438524461341e.gif
J
AudioBahn Alum12Q
FS:22.4Hz
Qts:0.47
Qes:0.52
Qms:4.8
Vas:76L
Vas:2.66ft^3
Re:5.4ohm
Le:2.7mH
Mmd:186Grams
Xmax:+/-14mm
RMS:1000W
Sd:0.049M2
EBP:47
Efficiency:96.4db
Depth:5 5/8''
Hole:11 1/8''
Diam:12 3/4''
Air Space: 1.75ft^3
Port Size
Port Vel:14.71%
-3dB: 30.1Hz
Tune Freq: 35Hz
Sub Disp:0.18
Port Disp: 0.092
Total Vol:2.0ft^3
J
