box building help for subs
riddla
nf
yo dudes, wats up,
my box dimensions are 34 Long x 16.5 W x 16 D...
I built this box off my head a long time ago & wana use it for 2 x 12in vibe subs rated at 350w rms & 700w peak power.
on the specs tho, it said use a box of 1.5cubic ft but what i wana know is how much would this box size be..
its got split chambers & i wana port it as well for the sub in each chamber..
fs in hz in 32
QTS=0.51
VAS in cubic ft=3.34
VAS in litres=84.50
Xmax in inches=0.29
Xmax in mm=7.5
max power in watts=700
QMS=4.86
Zmax=34.15
Fo in hz=32
magnet weight=50
recommended sealed enclosure = 1.5 cubic feet
This is the spec of the subwoofer & its calle vibe pt120 series..
Ive seen loads of these boxes ported from the manufacturer but i would like to know if the box ive made is suitable & how big & long sholud i make the port?
Any help would be graceful as this is doing my head in
Can someone please help with the mesearuments as im not to good at this sort of thing.
Ive built a box measuring
L =33.5in
H= 14in
W=13.5in
Ive used a divider in the middle & have place a 4in port of 11.5in into the box.
Ive tested the box after sealing it & it sounds wicked but i know i can make the box sound deeper.
How can i do this as there is no more space for me to increase the port length?
wat about a 90 degree angle in the box to increase the length, would that be ok.
Also wat frequency do u think my box is tuned to?
It sounds very good considering i just put it all together of my head
HELP PLEASE, CHEERS
thanks for the reply mate, the tuning frequency u mentioned i would say is wat my box sounds like.
dont get me wrong, the bass is deep but wat about making it sound deeper?
can i use a longer port with a 90 degree angle?
i want to get in the the region of say 25 to 35hz?
oh yer, there is a port in each division, 1 4in at 11.5in long as my box is 13in deep so i couldnt go any longer?
The crossover is just a pair of 3way, 300watt crossovers I picked up from from amazon. the subs I have are 8" Kicker FreeAir f8a I am looking...
4
855
My guess is, once you get the speaker in it, more like 34hz so good to go. With that unit, try it up, try it to the rear, see which works best...
12
237
I’m leaning towards the xv3 tbh. I’m also leaning towards adding the rings or if I can figure out how much taller to raise the top portion of the...
16
491
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
riddla
riddla
nf
riddla
Jimi77
    Jul 13, 2024
Jimi77
    Jul 13, 2024
