Wow, someone doesn't like being disagreed with, I suggest a midol.Ok smartass.
Let me clarify it for you, since you enjoy being cute and offering zero information.
In order to bottom the XXX, you'll first want to take a razor blade to it.
Take a knife to the suspension, and then cut the coil off the cone. THEN if you can keep the coil straight in the gap.... No... Wait... You'll run out of gap before you hit the backplate...
But I'm sure you were going to add that weren't you.
Ive never heard that term. And, its certainly misleading, as all drivers have a 'bottom'. I guess it was too much for jlaine to simply say that, rather than throw a tantrum. However, I stand corrected.actually...
within the industry, coil / motor combinations in which the coil does not reach the backplate are commonly called bottomless designs..
now I'm the correct smartass.....
Loyd L.
I was the correct smartass from the beginning, Mr. Fart-knocker.actually...
Loyd L.
In very simple terms, clipping is when you push the amp beyond it's outputs capabilities, so the amp "clips" off the top & bottom of the signal (the audio wave). Usual cause of very hard clipping is having the gain set too high. Usual fix is turning the gain down.so waht is clipping and how do you fix it?
Just the reply Id expect from you, Jlaine. Thanks for amusing me, once again. lol Nice threat there too, Im scared, really.I was the correct smartass from the beginning, Mr. Fart-knocker.
Audioholic -
Take your midol and cram it, you'll need it for future encounters with me.
Bigrick31 -
Adjust your gains to eliminate clipping, or turn it down. It's your amp saying it's at it's limits... You can't get any more out of it.
Assuming I even have a M.O. -I know, Ive been around a while, I know his M.O. I really have no intentions in fighting with someone, especially someone whose maturity level allows him to call people fart-knockers. (lol) IMO he doesn't need help making himself look bad. My original comment, albeit mistaken (as Ive found out), was not intended as smart ***. But what the hell, he amused me with his response, I needed a good laugh. And the midol comment, I was serious, I think it would really help. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Thanks for the advice tho. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
