Bolt-on's for '04 WRX
Mercureie
Stay in S-C-H-O-O-L
Just got a WRX and have got a list of the bolt-on's i want to do, just wanna know if anyone would do anything else.
For power- Cat-back exhaust, Piggy-back ECU, Cold-air intake.
For handling- Rear sway bar and endlinks, front strut tower bar.
I will also be gettin a set of 17 or 18's soon. Is there anything here that would not be benefical or is there anything more that would be nessecary? thanks for any input, i only have limited knowlege about this sort of thing.
get a whole new exhuast from the headers to the downpipe all the way back, that is where turbo charged cars benefit the most.
get a boost controler to help with turbo lag and turn up the boost. Front mount intercooler. My friend has a 2002? wrx and has exhaust and boost controler and runs 13.4 in the 1/4
ok the thing I don't get about what you said is why a front mount intercooler? what's wrong with where it is now...? not trying to be a dick, please educate me (I drive a Caprice... I know NOTHING about turbo cars... except I love the STi)
and don't the STi's hit 13's off the lot?
This car will be a daily driver for me and my brother so i am not trying to get tons of boost and mess with the everyday drivability of the car. I was looking at a few piggy-back systems that also have a boost controller in them. But before i do that i will probably get a new uppipe and downpipe to replace the factory ones, like wErd said. The only question i have is that replacing those will eliminate two of the three factory cats, is this still legal to drive with on one cat? There are three cats in the system on on the up-pipe, one on the downpipe and one on the final exhaust tube, is it still legal to drive with only the last one, or should i get down and up pipes with high flow cats?
with one cat you should be fine depending on state laws. also you might want to get a turbo timer, it keeps your car at idle after you park it so it will keep the turbo spooling a little so it has time to "warm down" and increase the life of your turbine.
More air in more air out
I would run a completely new exaust set up with a high flow cat or cat's
Ecu for sure you have alot more boost you could be making this will increase that and change your A/f as well. you could run a manual setup (which is what I would do but you have to be careful and you would absolutely need a A/f gauge a good one too not a cheapie)
cold air intake would be a good idea
underdrive pulley
you can go farther but those are all basic mods that will give you a good amount of power without sacficing much and they all support future mods
i thought about a cold-air intake but have heard that it will make the wrx run lean and should not be added until the proper fuel adjustments are made. So i prolly would nto want to get that cold-air intake until afte i get an ecu. How much do turbo timers usually go for, and are they easy to install?
front mount are bigger than the stock intercooler. The stock intercooler also lays right on top of the engine itself, hot air rises, so that has some affect on how cool the intercooler can cool the compressed air.
but umm... the scoop on the hood isnt there for looks. right under that is... you guessed it... the top mount IC. Plenty of cooler air coming from outside
Mercureie
Stay in S-C-H-O-O-L
Mercureie
Cleveland, OH
rjorunner
Jared Schwersky
    Jul 19, 2026
Jared Schwersky
    Jul 19, 2026
