BMW e36 Show car install!!!
M3wannabe
London
Ok guys,
I need a little help with this install, I think I need a split charging system with a second battery due to the ammount of gear wired up! however I am seeking guidance from fellow installers!
Overveiw of the system is
2 x 12" 400RMS subs
1 x Single channel 1000RMS D Class AMP
2 X 5-1/4 Component sets
1 x 4 Channel 400RMs amp
2 x 1.5 Farad powercaps with bridge link.
Also 10 7" LCD screens!
Now I know the standard car battery is clearly not going to be enough, I have never installed a split charging system I found a really good kit at
http://www.autoleads.co.uk/power_split.html
And since it is a show car I am getting these guys to sponsor us, provide any dist blocks etc
I am trying to figure out how best to set this up, i.e wiring up the powercaps, dist blocks? battery and amps?
All help very appreciated
Cheers
I had no electrical system problems with my stock alt and a red top optima in my E36. Which had 2 1kwatt class d's and a 800watt a/b amp. Televisions and x-box all going. No capacitors for me either.
Thanks for the input guys, however if I want to connect it up so that we can play the system at shows without the car running!. What kind of setup do you reccomend?
Thanks again
not sure i have a solution but i was woundering where the hell have u put 10 lcd screens 4 or 6 i can understand but isnt 10 a bit overkill, will have to show us picks when u done man.
deep cycle yellow top optima's would be your battery of choice. At least two, if not more depending on how long it was kept running. Also... a cheaper solution would be to set up a system to hide a battery charger(you can run the car while using some chargers, without having to run the engine). Then it will run off of a regular wall outlett not the battery.
U have to ignore that idiot !...thats the next thing i would do is check wires.i would run new beings how the wiring is old.
7
Look at Recoil components front and coaxials rear. Cheap solution. The Taramps is fine, or Recoil, or blackbrick 100.4 for $69 shipped. More...
I have a pair of IS BMW 100L on order. The next upgrade will be the center and/or the amplifier. The Focal center is much cheaper, however many...
11
Sounds like you already have a plan. Hook it up and let us know how it worked. Good luck.
M3wannabe
M3wannabe
London
BMG
Bobbytwonames
    Jul 20, 2024
Bobbytwonames
    Jul 20, 2024
