Best wire for Big 3??
1/0 is fine for the big 3, they aren't that long of runs, and usually 4 gauge is big enough if your planning on leaving the stock wiring in place.
thanks for the help. im leaning towards the kolossus fleks. would i use the 1/0 for all three cables? and also approx how many feet of wire would i need to order to be on the safe side?
the kolossus flex is great. if you can, i would go with some welding cable or kicker hyperflex. the hyperflex is really flexible and silver tinned ofc.
It really depends on how much current your alternator produces, but 4 gauge wire along with the stock wiring (if left in place) is more then enough for any stock alternator easily. If you want a more clean looking intsall, then replace the stock wiring with all 1/0 and you will be fine. It comes down to your budget.
I mean you can go overkill if you want, but 4 gauge wire can handle up to 250 amps of current in up to a 4 ft run.
just use 1/0 gauge and dont ever need to look back on "if" or buts. i used kicker hyperflex cus all my other wire was already kicker and figured id run all same brand, but i think any wire will do the job. i hear kicker wire is pretty **** good though. a little ore expensive. a 20 foot spool will run u at about 95 bucks on sonicelectronix.com (thats the cheapest i was able to fnid it) or see if anyone has it here on the classfields. thats where i got my run
Not friends at all. I see are you are another JP hater with zero proof of anything. He wasn't even driving that truck. Haters will always hate. He...
16
545
tgraham09
tgraham09
Linesville, PA
robertoyoung08
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
