best places to put brown bread
97acuratl
yea, im just putting the finishing touches on my plan for my stereo. I purchased 15 square feet of deadener and im wondering what everyone's opinion as the best places to put it.
My car is a 4 dr acura tl and it has pretty bad road noise. I was sorta planning on putting a layer of rubberized undercoating in the 4 wheel wells.
as for the brown bread, i was thinkin
3/4 to 1/2 the front door (where the components are). (4 ft each)
some of the trunk, like the back wall and the lid maybe. (3 - 5 ft)
and wondering where the best place to put the rest. probibly whatever is left on the floor by the drivers feet and the passengers feet.
this is a reasonable rounded system, one sub in the trunk, components in the front, and 6x9 for light rear fill.
this plan is cheap cheap cheap and im not planning on buying anymore professional deadener but maybe other products like foam or something else?
Thanks,
Tom
actually, I say if you want proper damping of doors, you're prolly gonna use it all up doing the front doors.
Also, do look up and read on what damping mats can and cannot do. It might not be the best solution to soundproofing your cabin.
yes, you're right. Ok, with what little dmaping mats you have, I'd choose to use it on my front doors, especially directly behind the speaker. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
take care the problematic areas first then if you have more you can use it on other places. but like everybody said, 15 sqft is not enough to effectivelly reduce road noise.
I actually think that damping mats will not reduce road noise much at all. A caraudio manag once tried damping the WHOLE car, literally everywhere except the windows, and all they got at the end was a 3dB reduction.
Point is, damping mats reduce rattles and vibrations, flexing if you will.
Sound absorbtion mats, used together with damping mats will work wonders. I once thought the same, thinking damping mats will get rid of sound, but that's not to be. You need something to abosrb soundwaves effectively.
I have faith in second skin product, affter using damplifier and they offer soundproofing mats. I'll prolly order a huge load from them when i get my next project car.
Have a look into their vinyl liner, if you're into reducing road noise. I'm suprised at the amount of people who don't really talk much about this stuff and only damping mats.
each door will require 24 sq feet to properly dampen.
Brown bred is a vibration damper, not a barrier or absorber.
barrier reflect air borne sound
absorbers ...absorb it.
dampers reduce structure borne vibrations to inaudible levels.
a combination of all 3 is best...
ANT
If frequency tailoring circuits cannot be completely bypassed an equalizer will be inserted in the signal path of one (only one and the listener...
13
541
That's good. The thing is finding a like 4 way splitter. Giving the exact reading coming out of the speaker outputs. I'm think he wants a big...
42
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
12
941
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
9
97acuratl
97acuratl
Saskatoon, SK
ifandorbuts
Bobbytwonames
    Jul 24, 2024
Bobbytwonames
    Jul 24, 2024
