Best amp for a pair of 10¨ W7??
for two w7 i would go with the most powerful amp you can find in the stores, ur going to need it.
try harrison sound labs, crossfire class d, memphis class d lets see earthquake phd ummmmm get the idea? i dont know how much you want to spend but those will work as well as us amps. class d will get you the most bang for the buck while a class a/b will cost you more but sound a little better. you have thumper woofs so i would guess you are leaning to the class d side.
im not sure bout this.....how bout a pair of MTX 8100D mono amp?? 1500 RMS @ 2ohm load at 14.4volts, im sure its gonna deliver the power needed for the w7s... ZR1000 will always be at the picture being one of the most use subwoofer amplifiers. Try to consult some professional installers and see what should be done.
MaKo_TM
MaKo_TM
Tucson, AZ
m83x
Giles
    Sep 4, 2026
Giles
    Sep 4, 2026
