Battery terminal question?
generally, terminals are terminals. they maybe labeled or colored for a negative terminal use but they should be the same as a positive terminal.
my aftermarket terminals look exactly alike.. only a very small idicator telling me whether it is positive or negative. Either case, your question is like "can I use the red color wire as my ground". No diff my man, if you found an awesome negative terminal cheap, go for it! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
On a normal car battery the negative post is smaller than the positive. A positive terminal will not make good contact on a negative post and a negative terminal will not fit on a positive one. The Stinger Expert series will fit on either, but they come with a brass sleeve that slides over the negative battery post to make it the same size as the positive.
I guess the majority of batts sold in Asia are different then. We get the same size terminal posts. I should check out the optima and see if it's different too. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
620hpcrx
620hpcrx
Bellingham, WA
paikiah
BP1Fanatic
    Apr 25, 2025
BP1Fanatic
    Apr 25, 2025
