Bad Backround sound
sasquatch
I have a soundstream 160 w amp and i am using it to power my rear 6x9's but i use a eqlizer as a x-over to elamate the bass from them but it has the worst backround sound i tried to hook it up with out the eq and no backround sound //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
i need help thanks
What brand brand is the EQ? How old is it? Try moving the band slides all the way down one at a time. Does the hissing only seem to be comming from one of the slides? An EQ enhances frequencies which can also boost a hissing noise. I have the same problem with an EQ pedal for my guitar. I have found that upgrading the signal wiring to high quality wire helps reduce the hissing sound. Otherwise I just had to turn down the slide a little bit that was causing the hissing and adjust the rest of the EQ to compensate.
sasquatch
sasquatch
canada
natem33
Jared Schwersky
    Jul 19, 2026
Jared Schwersky
    Jul 19, 2026
