Audiobahn Subs / Amp Help Please
go with a jbl 1200.1 amp..its a monoblock and its pretty **** good..also..u could get a jl audio 300/2 amp..its 157 watts x2..but if u bridge it at 4 ohms its 375 watts x2...thats 750 watts total..that should go good with ur subs..cause i have a jl audio 300/2 and a pair of audiobahn aw 12 inch ecursion subs they are at 700 rms..and it goes really well..if u have the money u could get a mtx 81000d amp..the cheapest ive seen that online was 410 bucks at http://www.carstereotime. good luck man
oh yeah the 300/2 amp ive seen for 280 bucks..and the jbl is about 300..this is the cheapest..ive seen them at...any would suit ur needs..just dont go and get lanzer or pyramid cause it says like 1000 watt amp for 150 bucks...they ****..when i was new at this stuff..i thought they were good until i heard and asked about them here..i still have alot to know but wut i do know is good amps usually are good ..and remember u get wut u pay for...if u run 700 dollar subs to a P.O.S amp then its gonna sound like crap.
Thanks so much !! I like JL amps too........
OK - If I had to do TWO AudioBahn amps what should I look for in them as far as Specs.
Im really hooked on doing an all AB install.
I thought since the Subs are 600 I can get like Two 200 amps and be Ok since I will never play it that loud. Or - is it not a matter of loudness but a matter of certain specs on the amplifier...........
Im so new to how to figure out what I need to run these subs.
Thanks !!
if u look at any other post they talk about the jbl 1200.1 amp..and if u hook ur subs up in parallel at 2 ohms each of ur subs will be getting 600 watts..for a total of 1200 watts..u dont need to get 2 amps..and as for audiobahn amps..i think they are overpriced
MicksGTZ
MicksGTZ
GA
cmp69
Doxquzme
    Aug 17, 2026
firey_kimchi
    Aug 17, 2026
