CBFryman2
Banned
I'm TSing the girl's little brothers 4-wheeler. It is a 50cc Polaris Scrambler.
The inital issue was running for 100 feet or so then dieing. I solved this by reconnecting a crank case vacume hose, fuel return line, and adjusting the choke.
Now it will run all day long but only at half throttle as if it where starveing for fuel. If you try and go full throttle once warmed up it will die. Any ideas of that to TS next? It isnt the intake as I have it removed. Exaust spark arrestor maybe? Clogged fuel filter? It will run wide open after you get her started but then after it gets good and warm it will start smokeing and only runing at 1/2 throttle.
Thanks. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
