Attention all PG Tantrum 1200 users
basketball346
I just got my PG Tantrum 1200.1. And i was wondering what size alternator u guys are using to power this....i will be upgrading mine soon enough but i'm unsure what size i should get. I called a car audio place and they say 300 amp, but i dont know if i can afford that. The amp pulls 155 amps at a normal rate, 170 max. So what size alts do u guys use? thanx for the help guys....i have a 95a alt right now so i def need a new one also could u tell me where to buy them for cheap?
Thanx
basketball
When ordering an alternator online, make sure to find out how it's mounted, it might be direct bolt-on, or it might require some form of bracket modification/fabrication. Also, ask about warranties and a return policy in case it doesn't fit.
I would put the full range to ch.3&4, and low pass on ch.5&6. The 6.1200 line out should be full range unless it has a dedicated x-over. In that...
It should be fine as long as you're not looking to upgrade in the future.
  • Poll
Its not a huge upgrade and I'd argue you likely couldn't tell the difference.
3K
  • Locked
I have one if you are still looking
basketball346
basketball346
Nazareth Pennsylvania
Gauntlet
Jimi77
    Jul 13, 2024
Jimi77
    Jul 13, 2024
