Any problems with hooking 2 different size amps to same speaker?
I wouldn't try it.
This quote is from Nick over at ssaudio.com, and is referring to a question asking would it be ok to put 2 identical amps on a dvc sub, one on each voice coil.
Yes, but the gains MUST be matched EXACTLY to put out the same exact amount of power to each coil. Just even the slightest bit off and you can kiss your sub goodbye. AKA: The gains need to be set professionally with a volt meter to each other. It's very very tricky, but it can be done.
So I really don't know how you'd do it with 2 different amps.. I wouldn't risk it, especially with an expensive W7.
I have had bad experiences trying to mess with amps that way. If you set one amp on each coil you will blow the sub in a few minutes. If you have the coils in series or paralell and you try to plug two amps into it, you will destroy your amps and prolly the sub too.
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
4
Will you post a picture if the LC2i as it is wired. How did you set the output gains of the LC2i? What is the max voltage gain input on the amplifier?
I feel like its a bad set(Low tier set) of RCAs myself. I use Stinger Zero Noise and 4000-8000 series without any issues. Dayton makes a nice set...
6
95civicHatchbac
95civicHatchbac
Dallas, texas
B_Master_Flash
Bobbytwonames
    Jul 24, 2024
Bobbytwonames
    Jul 24, 2024
