Featured Angled surface mounts for tweeters
maylar
Electrical Weenie
I have a set of CDT components that I'm going to use for my front stage. The factory tweeters are in the A-pillars and I want to retain that location, but the axis is not centered very well. The comps come with an angled flush mount and I'm wondering if they actually allow you to change the direction of the tweeter's axis? Some fabrication would be required but I insist on using the factory locations and not going with pods. Anybody used this mounting style before?
Using an angled flush mount for tweeters can definitely help you optimize the soundstage while keeping the factory locations in your A-pillars. The angled design allows you to redirect the sound output of the tweeter, helping to improve the imaging and clarity.
### Here’s how you can proceed:
1. Check the Angled Style: Make sure the angle of the flush mount aligns with your seat location for optimal sound imaging. The goal is usually to point the tweeter towards the listener, which might require some adjustments or additional fabrication if the mount's angle isn't sufficient.
2. Fabrication: If the flush mount isn’t adjustable enough for your needs, consider using:
- Wood or MDF Rings: Creating rings that can be angled accordingly and mounted behind the flush mount for more pronounced direction.
- Enclosures: If space allows, a small back enclosure can enhance sound quality and fit the tweeter more securely.
3. Test Fit and Sound Check: Before final installation, do a rough fit for the tweeters to see how the angle works with your listening position. Playing music while adjusting the angle can help you find the sweet spot.
4. Installation: Secure the tweeters in place with the flush mount, ensuring they are stable. Use silicone or similar material to dampen vibrations if necessary.
5. Evaluate: After installation, take time to listen critically to the soundstage and imaging. Fine-tuning the angles through small adjustments could lead to a significant improvement in audio quality.
### Additional Tips:
  • If possible, consider damping materials around the tweeter area to minimize unwanted vibrations.
  • Pay attention to the crossover settings (if applicable) to ensure a smooth transition between your tweeters and midrange speakers.
Anyone else with experience in this setup or variations in mounting styles? Your input would be valuable!
If this is the location, you should be able to surface-mount the tweeters there, with the angle providing the correct offset to get them about 10-15 degrees off-axis, which should be fine.
I would start by cutting the area where the tweeter will go, then rotate them, listen, rotate some more, listen, etc.
maylar
Electrical Weenie
maylar
Connecticut
Doxquzme
Giles
    Sep 4, 2026
Giles
    Sep 4, 2026
