is it really bad when the ground wire and power wire accidently touch each other when the power is on? Today i finally installed my amp (first time) and while i was moving the amp over the ground wire got a lil loose and then touched the power wire. I heard a lil electric shock but the amp light was still on so then i immediate turned off the system and took off the negative battery post. i then re redid the connections to make sure they wouldntlt touch each other but when i tried to put turn the system back on the amp wont turn on.
I have a rockford punch 4080 dsm and i was wondering if the little red light supposed to always be on. The first time when the when i put on the negative battery without the keys; the light was on.
