amp to subs question
  • Thread starter D.J Boss
  • Live activity
  • Replies 4
  • Views 2K
D
D.J Boss
Guest
I need to know the best way to connect my subs to my system. The way I have it now,I'm using a pioneer head unit model DEHP7200,I'm using the sub output on the radio to go directly to a two channel amp in stereo I'm running two 12inch subs Which are 4 Ohm svc, they each handle 500rms. The amp can be bridged to 4ohms mono 2ohms stereo the power per side is 400rms stereo 800 bridged..I basiclly need to if, I should keep them running stereo or should I run them mono,I was thinking of getting a mono block amp and wire the subs inn parallel droping the ohms to two.The amp I'm looking at can handle down to a 1 ohm load. Which is better mono or stereo. THANKS PLEASE HELP ME DJ BOSS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
can u bridge your current amp?(using one sides neg and the others pos, should have a diagram in front of the speaker outs showing u which ones)
are your subs svc or dvc?
are they 2. 4, 8 ohm?
what is your amp stable too?(ohm wise?)
answer those questions and someone will be better able to answer yours.
dude, my bad!:eek: i just can't read.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
anyway, wire your subs in parallel and bridge your current amp.
i don't know what quality stuff you have but that's seems to me to be the best way to go for your subs and amp.
again,sorry about my previous post. i need to re-read everything b4 i post!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Don't bridge current amp...
(2) 4 ohm subs in parellel equals a 2 ohm load.
Your current amp will turn to melted goo if you try that, you said that it is only stable to 4 ohms in mono configuration. Get the one ohm mono amp for some real power (if you need it.)
On subs, as a rule of thumb, Stereo or Mono is just how to make power...Sound Quality really doesn't change, unless you take into account how your amp works at lower ohm loads;
When you lower the ohm load of your amp...distortion increases and the damping factor decreases...your bass will sound worse...UNLESS you have an amp that is spec'ed out to handle that.
Guest
IASCA pro 301-6
Giles
    Sep 4, 2026
Giles
    Sep 4, 2026
