Bumpbump
Subwoofer wiring information
Amp & Sub Matching – Something I See People Get Mixed Up On
One thing I see come up a lot with subwoofer setups is people looking at the RMS rating of the sub and the wattage of the amp and thinking that's all there is to matching them.
The final impedance matters just as much.
For example, if you have a DVC 4-ohm sub, each voice coil is 4 ohms. Wire the coils in parallel and the final load is 2 ohms. Wire them in series and you're at 8 ohms.
With two identical DVC subs, there are even more possible combinations depending on how the coils and subs are wired.
That's why I'd figure out the final load first, then look at what the amplifier is actually rated to produce at that impedance.
Something else worth remembering is that the impedance printed on a sub isn't necessarily what a meter will show across the entire frequency range. A speaker's impedance changes with frequency, so the nominal 1/2/4-ohm rating is what we're generally using when talking about amp compatibility.
And don't forget the amp's minimum rated impedance. If an amp is stable down to 1 ohm, that's one thing. If it's only rated for 2 ohms, wiring it to 1 ohm because "it still plays" isn't a good idea.
Same thing with RMS power. I'd pay more attention to the manufacturer's RMS ratings at the actual impedance you're going to run rather than peak/max numbers.
For anybody building a system, the order I'd use is:
1. Pick the sub(s).
2. Figure out the voice-coil configuration.
3. Calculate the final impedance.
4. Make sure the amp is rated for that load.
5. Compare RMS output at that impedance with the sub's RMS rating.
6. Then worry about gain, crossover settings and the rest of the setup.
Just throwing it out there because I've seen people buy the amp first and then try to make the subs work with it afterward. Sometimes it works out, sometimes it creates a wiring/load combination they didn't realize they were getting into.
1. Pick the sub(s).
