Amp settings!!!!!!
popothemailman
Hey can you guys help me out.
I have...
- 6.5 Componant type R(176A) in the front
- 4" Type S 2way in the back
they are connected to an Alpine MRV-F340
i found this chart from RF:
Common Frequency Ranges for the crossovers
SUB BASS MID BASS MID RANGE TREBLE
20Hz-100Hz 100Hz-250Hz 250Hz-5kHz 5kHz-20kHz
which ones do i set them for my speakers?
im thinking the type r's will take a diff frequency, but i dunno?
please help
I also have an RF 1001bd connected to my Sub, what should the crossover be set to that one, and should i have my Subsonic filter on?
thanks i super appreciate it
well your sub will handle the sub bass (20-100)
the speakers in both of your speakers/sets will handle the mid bass and mid range(100-5k)
and the tweeters will handle the treble (5k-20k)
i think my comps are both hooked up to the same crossover thingy, so when i change the freq for the type R's the comp speakers will be the same as the tweeters
The switch goes between the speaker and crossover.
43
5K
set your gain right, heres how. test tones are at the very bottom...
6
You will need a multi-meter, a set of RCAs that will be sacrificed, and a small blade screwdriver. First disconnect the amp from the LC2i. Now cut...
Thanks for the info, made the setting changes and that did the trick. Toyed with the amp gain to get the amplitude balanced out, then tweaked...
4
popothemailman
popothemailman
Oakland, Ca
popothemailman
Jimi77
    Jul 13, 2024
Jimi77
    Jul 13, 2024
