AMP settings for my SX 15"
Loudrango112
OK QUESTION!!!!!
I just got my amp in and my sub should be here in litterally 1-2 days.... NOW what do you guys recomend my amp to be set at AFTER I BREAK MY SUB IN?
here is a pic of it if you need a reference...
The bass EQ can be turned most of the way up I think,
Depending on how loud you want your subs to be.
I have mine a little over three quarters of the way, but I've heard other people who have that amp who run it at 100%.
I have a BX1000D...
The bass EQ can be turned most of the way up I think,Depending on how loud you want your subs to be.
I have a BX1000D...
I've read on this forum that turning up the bass EQ all the way can actually hurt your sub. It gives it that "boomy" sound and stresses it.
I have to have mine up most of the way b/c of the factory amp though.
alright disregard everything that has been said so far cuz it is ridiculous.
To tune and amp....
1. Tune HU setting how u like them and how u would listen to them.
2. Make sure gain and bass boost is all the way down.
3. Turn the volume up on ur HU as high as u would listen to it
4. Start turning up the gain until u hear the subs distort or when u know its too much and theyr not getting any louder and turn it back down a tiny bit.
5. Set ur Xover (LowPass for subwoofers High Pass for Mids) how u like it generally 80-160hz for mids/highs and 90-120hz for subwoofers.. Only use ONE LPF and ONE HPF, whether it be the head unit, external, or internal amp one, only use one.
set ur low pass before u do ur gain though. then mess with it to ur liking after the gain a little more.
Awsome you guys are the best.... my sub should be here today so Ill break it in and then get my amp all setup //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif:)
Loudrango112
Loudrango112
New York
Loudrango112
BP1Fanatic
    Apr 17, 2025
BP1Fanatic
    Apr 17, 2025
