AMP Recommendations
i just designed a box to hold 3 Jl Audio 10 inch W7's and a single box to hold one w7. i want to know the best amp setup to run these four subs. is it better to get one big amp or two smaller amps. Money could be a problem but please don't take that into your recommendation. i want the subs to sound good since i put 1200 on them. if the box will help make a better decsion. i am in middle of building the box that will hold 3. i designed the box for each one to have its own chamber with 1. 25 cu ft of air taking into considerration of sub displacement. by the looks of it the volume will have to be a little smaller due to lack of room. the single box will just be made to the same volume as the other ones when i get it finished. thanks for all recommendations.
1999Ford_f150
1999Ford_f150
Orlando, FL
1999Ford_f150
KcContractor
    Mar 18, 2025
KcContractor
    Mar 18, 2025
