Amp Question
  • 2
1976Olds
CarAudio.com Recruit
I bought a Kicker cxa 600.1 amp off of Facebook and was wondering if I need to have it set up as high or low imput level. I am using a new radio with a sub output. The radio is a Custom Autosound USA740. I am running 2 old 12" Rockford Fosgate subs now but will probably switch to a single 12 in the summer. If you have any decent sub suggestions for this setup that are in the same price range as the RF p3 that would also be greatly appreciated.
Thanks
This will be a low output, so set amp to low input.
That amp drops to 2 ohms minimum, so a dual 4 ohms sub is what you will be looking for. RF P3 subs are good, but the ported box will have to be 1.79 cu. ft. Make sure you got the space for that.
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
If you do use speaker baffles.. I recommend the plastic ones rather than the foam ones, and drill a 1/4" hole at the bottom of it in the back for...
Haven't 100% landed on which one, but I am down to those two
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
1976Olds
1976Olds
Wisconsin
Bobbytwonames
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
