amp question
camflan
I have a dual 10 setup in my trunk with two boston competitor 10" 2ohm wired in series (4 ohm) to a sony xplod XM-D400P5. I know this isn't the best amp, but i got it new for 69 bucks after i blew my alpine v12 and was on a budget after buying a alpine 9835 hu (SWEET). is this enough? suggestions? still kinda on a budget, any suggestions?
I talk about these boxes a lot, maybe cause Im biased, but they are just great boxes...
12
417
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
5
If you do use speaker baffles.. I recommend the plastic ones rather than the foam ones, and drill a 1/4" hole at the bottom of it in the back for...
9
Haven't 100% landed on which one, but I am down to those two
12
camflan
camflan
Lawrence, KS
camflan
Bobbytwonames
    Jul 20, 2024
