amp for old school kicker solobarics
shareef777
i've had a set of 3 10" kicker solobaric, round subs. I had them in my eclipse for only a few months about 3 years ago, and have had them lying around since then. i've completely forgot the specs on the subs, but my friends tell me that they are rated at 500rms, 700 max a piece. if that is the case, what is a good amp i should get for them. i had a rockford 800a2 wired parallel mono, and they sounded really good. but the accident i got into with the eclipse damaged the amp. should i go for a bigger amp??? i'm really lost, i had a shop install my last system, but this time i'm going to go for it on my own.
any suggestions would be appreciated
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
I updated the original post to simplify it a bit and re-frame it with the new Scosche floating ground adapter. This adapter *is* different, as it...
4
shareef777
shareef777
Worth, IL
shareef777
Jimi77
    Jul 13, 2024
Jimi77
    Jul 13, 2024
