Am I just that stupid, or is this actually a decent deal?
AllStar1500bd
Times have changed
Check this out...
http://www.woot.com/
Even though it's refurbished... $84.99 shipped for a 1000w RMS 5.1 system isn't that bad... or stay the hell away?
Specs: (if you're too lazy to read the site)
Amplifier Section
  • RMS Output: 167 Watts per Channel (1KHz, 8 Ohm Dolby Digital Mode @ 10% THD)
  • Total RMS Output Power Dolby Digital mode: 1000 W
  • FTC Output Power Front and rear: 75 Watts per channel (1KHz, 8 Ohm, Dolby Digital Mode with 10% THD)
  • FTC Output Power Center and subwoofer: 155 Watts per channel (1KHz, 8 Ohm, Dolby Digital Mode with 10% THD)
  • Total FTC Output Power, Dolby Digital mode: 610 Watts
  • Muting Attenuation: 65dB
  • Frequency Response: 200Hz/-3dB, 1kHz ref.
  • Subwoofer Frequency Response: 10 Hz / -3db, 80Hz ref.
  • Signal to Noise Ratio: 65dB (Dolby digital mode)
AM Tuner Section
  • Frequency Response: 2kHz +/-6dB, 1kHz ref.
  • Usable Sensitivity: 800uV/m @ S/N 20dB
  • Signal to Noise: 38dB
  • IF Rejection: 35dB
FM Tuner Section
  • Frequency Response: 15kHz +/-3dB, 1kHz ref.
  • Quieting: 24dB
  • Signal to Noise: 60dB(stereo) / 65dB(mono)
  • IF Rejection: 50dB
Dimensions (H x W x D mm)
  • Unit: 430 × 140 x 347
  • Front and Surround Speakers: 143 × 80.5 × 93.7
  • Center Speaker: 80.5 × 271 x 72
  • Subwoofer: 355 × 195 x 325
Seems like a decent little setup. I would snatch it up.
I have a Philips upcovert 1080i DVD/1000rms surround sound system in my bedroom and it sounds pretty dam good. Have it hooked through HDMi though. I spent 135 at Best Buy though, still not bad.
Good luck and enjoy!
AllStar1500bd
Times have changed
AllStar1500bd
Oregon
Eugenics
