Alternator Change
alexis gutierrez
CarAudio.com Newbie
I have a small sound system that use 4 gauge ofc wire and it is connected to a 150 amp fuse, i got a stock alternator on my silverado 4.3 v6, im planning to change it to a 240 amp and do the big 3 upgrade, will I have to change the fuse and 4 gauge wire hooked up to my sound system too?
For recommendations on electrical upgrades, you may want to consult with a car audio specialist or a professional installer.
Hello Alexis.
Disregard the Ai bot. You will not need to replace the fuse or the 4-gauge wire, unless you are power a system that is more than 1500 watts RMS. Either way, if you replace a alternator, you do not have to replace the amp wires or fuses.
Hello Alexis.
What about these wires?
Follow this chart when needed. As you can see, even with a 250a alternator, you would not need to change those short runs from the battery. For "peace of mind" you can change those wires to 1/0awg OFC and never have to think about them again.
Be aware, some of those factory cables are smaller than 4awg. I have seen 6awg being used from the factory and I have sold the same when I sold auto parts. It doesn't cost much to upgrade the cable if you buy piece by piece by the foot as you can fit it in to the budget "as needed". For example. A 5ft length of 1/0awg ofc to run first from the alternator to the positive of the battery. One part of the "big 3" done.
$33.75 + shipping for the stuff above... there are other more expensive and less expensive options.
This is a killer deal!!
alexis gutierrez
CarAudio.com Newbie
alexis gutierrez
Texas
alexis gutierrez
Giles
    Sep 4, 2026
Giles
    Sep 4, 2026
