Alternator & Battery Q's...
  • Thread starter Unregistered
  • Live activity
  • Replies 3
  • Views 788
U
Unregistered
Guest
I have the following...
- JBL Pro Power P-80.4 Amp (4-channel)
- Infinity Kappa 52.3i 5-1/4" 2-way 225W Speakers (Front - Pair)
- Infinity Kappa 63.3i 6-1/2" 3-way 225W Speakers (Rear - Pair)
- Rockford Fosgate CP7400 1 Farad Cap
- JBL BP1200.1 Power Series Mono Amp
- Infinity Kappa Perfect Subwoofers 12.1 (Pair)
- 12" 1.25cf Dual 3/4" MDF Hatch-Style Subwoofer Box
- Pioneer DEH-P740MP CD/MP3 Player - OEL Display
With this setup, how powerful should my alternator be, and what kind of battery should I have? Any ideas of where to buy both of these cheap? By the way, I drive a 1990 2-Door Chrysler LeBaron Convertible GT. Thank you!
2 Gauge main power wire(don't forget the ground wire too)
1 or 2 farads of capacitance
Optima 800 cold cranking amp battery( a regular 800cca battery will work, I just really like the optimas)
An alternator rated for at least 125amps
This should keep your lights nice and bright.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Okay, so how about these...
47ZX6331Y - 140-amp Chrome-plated Alternator $149.95
EXIDE ALL CLIMATE 78DT-84 $71.99
Superior; 850 CCA; Dual Terminal
It sounds good to me, up here in Canada, I would have to shell out at least 200bucks for that same alternator, and Exide makes good battery's so you should fine with that equipment.
Upgrade to a capacitator if you find that your transients in the bass are a bit sloppy and don't skimp on the power wire.
A couple suggestions for cheap power and speaker wires are -
WELDING CABLE- Its cheap and can handle high current, downside is that it will oxidize over a few years(white crusty crap on the terminals) but if you are constantly changing your system around every couple years, oxidation should not be a problem.
LAMP CORD- Its cheap and will make great high power speaker wire, but it has the same drawbacks as the welding cable. Whats the difference between the two?-Oxygen free cables are the most resistant to oxidization and lamp cords and welding cable/boostercable are not made from oxygen free copper, therfore they will oxidize over time( 2 to 3 years in an automotive environment ).
Guest
stones
Doxquzme
    Aug 17, 2026
firey_kimchi
    Aug 17, 2026
