Altenator Question
68 R/T
Im Putting A System In My Durango And I Was Planning On Using Two Ppi A600 Amplifiers. One To Power My Two Kicker 15 Subs And The Other To Run All My Mids And Highs.i Was Thinking Of Putting In A 130 Amp Altenator And Keeping The Stock Battery For Now.think This Is A Good Idea Or Should I Do Something Better.
Thanks.
Your stock battery should do the trick. I would install everything first and see if you even need a bigger alt. I just installed a concept d-800 and an apline 1,000 watt 5 channel amp in a ford ranger with a stock alt and battery and did not need to upgrade anything.
After you install everything take your truck to a ALT shop and have them test the AMP draw on your system. Turn on everything A/C, lights, and radio and see what you are pulling. Put a big ground (4 ga min) wire on and make sure you do it right. This is a major cause of a lot of problems with systems.
I talk about these boxes a lot, maybe cause Im biased, but they are just great boxes...
12
455
https://www.amazon.com/dp/B0CJB5TTPB/?tag=caraudiocom-20
8
783
LOL - mine was a higher end model too - iirc deh-9300. Low mileage too, it was sitting around for year collecting dust.
7
818
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
68 R/T
68 R/T
TORONTO,CANADA
pavengmike6
Bobbytwonames
    Jul 24, 2024
Bobbytwonames
    Jul 24, 2024
