Alpine Type-R subs
fresh
Hi all,
I have an Alpine V-power MRP-M350 class-D Mono amplifier and wanted to know the following:
Can I hook up 2 10" Type-R subs to it? Will it handle it? Or will I be way under-powering the subs and overworking the amp? Oh by the way, the subs are the (4ohm + 4ohm) type.
The reason I ask is because I already have 1 of the subs and the amp working very nice and wanted to upgrade to 2 10s instead for a relatively cheap upgrade (just the price of a new sub and box).
As a side note, I have an older JL 10" W1 sub, and a PPI entry level 10" sub. can I mix and match especially with that mono-amp or is it simply asking for trouble and is a bad idea?
What do you guys think?
Thanks in advance
Fresh
Well that amp is 2 ohm stable. Since you have DVC 4 ohm subs, you can wire them to a 2 or an 8 ohm load. If you added a 2nd sub, that was dvc 4 ohms then you could get 1 or 4 ohm final mono load. IF you ran that amp at 1 ohm, it would probably break and if you ran it at 4 ohms, you would only get 1/2 the power from the amp.
As for mixing and matching subs, I don't recommend it. Plus you will still have the problems with that amp only being stable to 2 ohms.
what does that mean? can I or can't I add a second Type_R sub to my system?
If I run the amp at 4 ohm, will I be getting enough power to power up those Type-R puppies?
oh and by the way, how do I do that?
Thanks again
fresh.
you can add a second type r but you will be sending about 100wrms to each sub with a 4ohm load. The subs could use a lot more power than that.
I would probably upgrade the amp in your case or just stick to the one sub.
if you want the 2 sub setup get an amp that's 1ohm stable and you'll be fine.
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
On a sealed sub box if I faced the subs up, I lost quite a bit of bass. Faced them forward, they worked great. On a ported box with subs and...
I would just go with a ported box tuned from 32 hz. - 35 hz.
fresh
fresh
Vancouver, BC
substance_x
Bobbytwonames
    Jul 20, 2024
Bobbytwonames
    Jul 20, 2024
