83 Turbo Ranger
Scorpion
Hey Yall,
I have a 83 Ranger that will have a 2.3L Turbo under the hood. Just wanted to know if you guys had any ideas about trannys for this thing. It did have a C3 but I shelled it doing 120 in a race last week. I figure I NEED to get a better tranny for it. Just suggest me something, I will listen.
This is my system so far:
Pioneer MP3 HU
Legacy 12 Band EQ
RF 501bd Amp for subs
Jensen Amp for surround
Kicker RMB6 and RMB4 for surround
Kicker Comp VR 10" Subs
Amps are mounted on roof of cab and subs have 1.5 cubes (sealed).
The C4 from a V8 will not fit for obvious reasons. But if you search hard enough you just might find a Pinto with a C4. It will bolt up but according to a ranger site I visited recently, it isn't a drop in swap.
My suggestion is if you want a better transmission and are going to go through with all the work to get a C4 to work, go with a T5 manual. They are fairly cheap if you know where to look, around $500 for everything. There are plenty of sites that have walkthroughs for this type of conversions. I have a Cougar with the 2.3l in it and the process to convert that to a 5 speed is basically the same. If durability is an issue, you could always run a 5.0 T5 instead of the 2.3l T5. But remember to get the correct belhousing.
Basically the only things to do is C4 or T5 swap, the A4LD has overdrive, but is very very weak. Just like the AOD for V8 cars. The best you could do for yourself and your truck is put in a T5. Although the C4 is a great tranny, its still a 3-speed. The 5 speed will be easier on you engine in the long run.
Hope this helps.
i honestly know bearly anything about these engines, but would a merkur tranny from there turbo 2.3 fit? i know alot of people use those cars as street race cars an there stock trannys held up pretty well, just an idea. Dont even know if it would work. may be wurth doing research on.
Scorpion
Scorpion
Goodland, KS
laserturbo
BP1Fanatic
    Apr 25, 2025
BP1Fanatic
    Apr 25, 2025
