6.5s ported or 8s sealed?
After a good stint of no bass I'm ready to put something back into my truck
Currently considering
2 dd1506 in 1cube ported at 35-36hz
Or
2 sundown sd4 8s in 1.05 sealed
While there is significant differences in cone area 66in² to 100in² I would be getting the boost from the ported box.
I don't have modeling software anymore so I'm only guessing game which one could reach lower in the bass range
I'm limited to an 8inch sub max due to mounting surface.
Will likely do sub forward port side.
Any advice?
I know sealed can dig deep, my last setup was a pair of 13tw5s and they dug into the 20s easily
I will eventually be doubling the speakers and building a 2nd box for the other side of the truck.
I am open to other setups as well but don't want to shoe horn 10s or 12s in. Would rather run smaller subs for something new
What truck?
It's a 2013 silverado 3500 crew cab
Can you do 1 10 ported?
I could but I don't want to, down firing I lose air space and upfiring is muffled.
Front firing I can only squeeze an 8 at max. Don't want to wait on a seat lift or rebuild my current box if I can help it.
mainly I've just been away from the brands for a while.
I've got 1000w conservative available but would like to run around 5-600w at 2ohm for the first pair and the drop to 1ohm for the second pair..
amp is a dd d5.1000, will likely be swapped for a d5.1500 at a later date for more headroom. Maybe a sundown if he ever releases the higher power compact 5 channels
Sundown is coming out with the new Nightshade Subwoofers and they will be released in the 8" version as well.
While I can fit an 8inch of decent size I don't think a night shade neo motor on the back of sundowns deep basket will fit. I think I can get about 10inch total but the downward slope of the box limits motor diameter.
And I don't think I'll have the power for that sub, not to mention it will likely be a peaky sub even beyond ddaudio peak due to super stiff suspension
Well, I'm an AB fan. So, I just bought four of these for my standard cab Dodge. 600 rms, mounting depth of 5.4", and 120 oz. Magnets. The original VFL8's (yellow ones) sound really good as well.
Well, I'm an AB fan. So, I just bought four of these for my standard cab Dodge. 600 rms, mounting depth of 5.4", and 120 oz. Magnets. The original VFL8's (yellow ones) sound really good as well. View attachment 25696View attachment 25697
I wouldn't be able to run 4 of those 8s ported they need a .75cube each and I can only give them .5cube.
My box fell out awkward. 3 6.5 fit perfect but I cant stand dealing with ohm loads and multiples of 3.
1 8 has too much airspace and 2 not enough.
Even with the 28s sealed the box is a touch large but not by much, same with 2 6.5ported just a touch big but not by much
So, go with two 8's sealed and shrink the box slightly. Or, maybe one of these will work. Mounting depth is only 6".
View attachment 25698View attachment 25699
I don't believe next to any American bass subs perform well sealed. They typically use stiff suspension and rely on ported enclosures to perform to peak efficiency
Two 6.5s ported by a large margin. 8 sealed will give you in average 2bd less
Idk how you figure that.
2 dd1506 is 66in² of cone area with 10mm of xmax 132in² if you call the rear wave essentially a second set of woofers. This moves 52in³ of air combining the front and rear wave
2 sd4 8s is 100in² with 14.5mm of xmax, the moves 57in³ of air
Honestly I don't see moving 5in³ more in the case of the 8s to be truly impactful. Though it does show the advantage of using the rear wave in a ported enclosure.
I scrolled thru there trying to find TS specs and must have missed them or they weren't displaying. Anyway, looks like 2cuft tuned to ~35hz was a...
For what it’s worth… I picked up a mti stage 4 or 5 for around 900.00. Loaded with jl tw3 it’s was 1995.00. Which is a good 1k off what I would...
Assuming the taget curve is the same they will sound very similar. 2nd and 3rd order harmonics might be different but are offer hard to even hear...
😂😂 I actually have a CNC at my shop (I make drone parts for a living). It’s just that I got intimidated by all the tuning (equipment I don’t...
18
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
Ponchatoula, La
Buck
    Mar 28, 2024
    Mar 28, 2024
