I have a four channel amp and it just occured to me by bridging the wire gets bigger so there is less resistance therefore less ohms ok well if I knew this to buy svc subs I would have but with a pair of dvc type R's and a 4 channel amp if I run a channel per coil is that a 4ohm load? Is there anyway to get a 2ohm load so I can get more watts outta it so I can run my 125x4 watt at 4ohm amp at more wattage in 2 ohm so I can get the full 300watts per sub? If I cant wire to 2ohm is 250 instead of 300 watts going to kill me and if I turn the gains down **** it that will **** but lets say I use half gain will that be ok!
