4 ohm, 8 ohm, svc, dvc HELP!
jkw_1
I'm ready to buy two 10's, but need some advice. I've got a Punch 200s (all I can afford for now). I've got a box ready to install two 10's, but need to know what to look for in a sub. The box is app. 1 cube for each sub.
ANYWAY.....I'm confused as to how to get the best punch out of the subs. Should I get a pair of 4 ohm svc's or dvc's or 8 ohm svc's or dvc's? I've always heard 2 ohms mono bridged off the amp is the best way to get full power. Is this true? If so, what ohm subs do I need? Are dvc subs generally better? Keep in mind I'm looking for a tight, hard hitting punchy bass for rock music, don't care for rap and all that.
Lots of ?'s but please try to help me if you can.
Jeff
2 4ohm SVC wired parallel to get you at a 2 ohm load.
2 SVC drivers with Voice Coils in Parallel
Resulting Impendance;
3 Ohm Subwoofer: 1.5 Ohms
4 Ohm Subwoofers: 2 Ohms
8 Ohm Subwoofers: 4 Ohms
12 Ohm Subwoofers: 6 Ohms
Get the dual 4 ohm subs, and wire each subs voice coils in parallel, then wire each sub to its own channel.
Ok, that will give me 2 ohms?
Anyone have a diagram on how to do this PLEASE?!?
Also at the amp, will both +'s be tied in together as well as both -'s and then the + to one channel and the neg to the other channel. So that would make it bridged right?
If he gets 2 4 ohm DVC's and wires each sub parallel wouldn't he have to have twice as much amp then if he had 2 4 ohm SVC's wired parallel?
As for the wiring check out this link...http://www.edesignaudio.com/ep2/wiring.htm
He has a 2 channel amp, his best bet is to have a 2 ohm stereo load, accomplished by having a DVC 4 ohm sub wired to each channel.
My bad! I misread your original post and thought you where telling him to get 2 4 ohm DVC's. Hence me coming up with the heftier amp comment.
AJ:D
https://www.the12volt.com/caraudio/subwoofer-wiring-diagrams.asp?Q=2&I=41
16
It also lowers the amps efficiency and raises the current draw.
5
997
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
767
jkw_1
jkw_1
South Texas
ActionJ-01-Z71
Bobbytwonames
    Jul 24, 2024
Bobbytwonames
    Jul 24, 2024
