4 nighshade 18s yukon xl build 155+ 16v
well the OP's should never ask for thought, advise or answers... because everyone has 2 cents. but there are ones you might want to listen to. and that be the ones that actually have the big system
if you want to know how to lift weights you dont ask the skinny kid, do you?
if you want to be smart you dont ask the kids that ditch school, do you?
if you want your car fixed you dont ask a chick, do you?
SO WHY IN THE FUK WOULD YOU LISTEN TO AZZCLOWNS THAT DONT HAVE A BIG SYSTEM???
sub2weeker
http://www.caraudio.com/forum/showthread.php?t=425954
you have come along way since your post 4 months ago. back then you didnt even know the proper porting for a box.... my favorite post was thats a sweet *** box, how do you determine tuning?
and now your a expert box builder congrats!
edit: lmfao you do 155's with 4 18's? i do more than that with two //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
me too lol
well the OP's should never ask for thought, advise or answers... because everyone has 2 cents. but there are ones you might want to listen to. and that be the ones that actually have the big systemif you want to know how to lift weights you dont ask the skinny kid, do you?
Just because you have a decent sized system with decent numbers you think ur opinions should rule over all others? You couldn't be more wrong. Numbers don't make your voice any louder than anyone elses. Nor does the ****ing caps lock either.
Watch these vidieos and you will realize what you are dealing with, obviously he is an expert on the subject.//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Sounds like he is stroking himself in the first one and the rest are almost as entertaining.
7 square inches of port per cube is a tad small... although not a bad box idea. 16 cubes is plenty for a common chamber no wall box for 4 18's. It might work well because of the sheer size of the vehicle.
I would try to make the back plate of the box removable, just in case you want to add a larger port later.
I found 9-10 square inches per cube worked best for a balance of daily while still meetering well in my explorer, w/ aero's..
so i could see 7 working in a yukon xl...
once again i have a bunch of punks thinking they know me....
this was a build log, and advise was given, then some punk kids came along and decided to say "no... its ok to build a box with 3/4 in and only a double baffle for (4 18's)
the post i made 4 months ago was to prove someone wrong on my port dimensions, which came out exactly as i planned...
the TNA clown that likes to hop on the leg saddles still cant buy wood because there is no lumber yard around is a ****in lier
Dnick the bisnitch went out and bought a konaki 12 because i made fun of his kicker comp
and aero ports are used only for spl when the are placed outside of the box as shown on his previous build, show me ten vehicles that have aero ports that are tuned to 27hz, or play music for that matter with 4 18s
and if i wasted my time to build a a sub enclosure for a 21" sub i would put a 4hp on that biitch and feed it 12k in a second.
once again the haters have come out to play...
TMH has 3 18's in his Tahoe tuned to 28hz
sub2weeker needs to be banned for constantly handing out bad information. He shouldn't be allowed outside of the thunderdome because everything he post is a fucking joke.
but it is rather entertaining //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
OP see what happens when you dont have pretty pictures for the boys to look at?
This thread suffers from chicks not kissing
GTbikes good luck on build this should be loud! I hope you do more than a 55 runnin on 16 volts //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif If not im sure it will still be loud!
gtbike900
1loudyukonxl
gtbike900
ohio
BumpinKota
RobGMN
    Jun 8, 2026
DEH-P7700MP.mp4
lbn.wrks
    Jun 8, 2026
